Cleco the Baggage Back Channels to the Baggage Back. Cut three L angles 675mm long. Draw a center line on one flange of each L angle. Mark the first hole 10mm from the end of the L angle and predrill a hole on the mark with a #40 drill bit. Cleco the predrilled hole to the first hole on the Baggage Back. Rotate the L angle until the center line is visible through the predrilled holes in the Baggage Back and clamp the L angles in place. With a #40 drill bit, back drill through the holes in the Baggage Back into the L angles and Cleco. With a #30 drill bit, expand the holes in the L Angles and the Baggage Back Channels and Cleco.
Remove the Clecos holding the Top Skin to the Longerons so that it can be pulled back to help install the Baggage Back. Cleco the Baggage Back Channels to the Side Skins. Clamp the Baggage Angle to the Longerons and to the Baggage Back. With a #40 drill bit, back drill through the Baggage Back into the Baggage Angle and Cleco. With a #30 drill bit, expand the holes through the Baggage Back and Baggage Angle and the Side Skin into the Baggage Back Channels. Cleco as the holes are expanded. Replace the Top Skin and back drill with a #40 drill bit through the Top Skin into the Baggage Angle and Cleco. With a #30 drill bit, expand the holes.
