Brief Description: L wingtip nav lens and nav light
With just a couple of hours available this evening, I had to be selective. It was just enough time to finish up the left nav light enclosure. I cleaned and scuffed the back sides of the reflectors, applied some Goop adhesive, then screwed them into position (with three SS screws on one side, and with the nav light iteslf on the other). Then I installed the connector shell to the terminals. Finally, I masked and painted the outside edges of the lens with a strip of black paint. I'll post pictures of that once it dries. The left wingtip is essentially done.
I also moved over to the fuselage and spent some time documenting the issue I'm having with the clearances on the flap rods. I will be sending some photos to Vans this evening. Maybe they can figure out what the problem is.
Pretty much finished with the L nav light enclosure.
