Brief Description: L wingtip nav light; L wingtip rib.
Spent a couple of hours finalizing the fit of the L wing nav light lens, then cleaned it up, drilled and countersunk the two attach holes, installed the nutplates, and filled the hollow nutplate rivets with SuperFil. Once these areas are dry, I'll sand them and paint the coves with flat black paint. Then both coves will be ready for the reflectors.
I also sanded, prepped and primed the L wingtip rib.
