Did some final trimming and fitting of the upper-right map-pocket, then drilled and clecoed it to the fuselage structure I had to make a slight joggle at the forward edge of the pocket so it matched up with the vertical channel cap, and also bent the bottom edge so it matched the angle of the armrest.
Upper-right map pocket, clecoed in place and ready for nutplates.
Closeup of the joggle I made in the forward edge of the pocket to make it flush with the channel cap.
