Today I fit the first of two fuel lines that will connect to the fuel flow transducer. The first one goes between the pump outlet and the transducer inlet. Since the transducer requires several inches of relatively smooth, undisturbed tubing upstream of the inlet, I had to take the line aft quite a way before making the final bend. I won't cut and flare the tubing on this end until the transducer is installed in its final location.
I also fitted the AN fittings to the transducer.
Installation of the fuel line between the fuel pump and the flow transducer.
