Because of the numerous fuel lines that must run through the left gear tower, I repositioned the smoke oil line from the left side of the fuselage to the right. I drilled four new bulkhead holes and installed snap bushings, then ran the line. It will have to be secured, of course, and I won't run it forward of the spar until after the wings have been attached.
