I riveted the F-866D mounting plate for the brake line fittings on the bottom edge of the cockpit bulkhead, attached the angle fittings and pedal brake lines, then began fabricating the pressure lines that will go down to the gear legs.
Front side of the attach plate. These brake lines come from the pedals.
