Buck's RV-8
Date: 3-29-2009
Number of Hours: 4.00
Brief Description: Fuel lines; parking brake deletion
I clamped the fuel pump to its mounting bracket today, then began tackling the fuel lines. OK, an admission: Last fall I measured for, and ordered, a nice set of Bonaco teflon-covered flexible lines for both the fuel and brake lines, thinking they would save me some time and effort. I thought I'd just be able to screw them right on, clamp them down, and move along. Unfortunately, the larger "Dash-6" lines for the fuel system are a lot stiffer and less flexible than I'd counted on. The 90- and 45-degree fitings I so carefully planned and ordered are totally inflexible, too, of course. There's no slop if you need another 5 degrees of bend within about 4 or 5 inches of the end fittings. This means the lines are nearly impossible to use in the locations I had planned. Today, I ditched almost all of them in favor of old-fashioned aluminum lines. This will give me a LOT more leeway with the bends and tricky angles in areas like the tight bend below the fuel filter, and underneath the fuel selector valve.
The first line I made was the one between the fuel filter outlet and the fuel pump inlet. I only had to make five of them before getting one that was perfect. Argh. Glad I ordered all the extra 3/8" tubing last month...
Another epiphany today: I simply cannot figure out an elegant way to install a parking brake valve and push-pull cable in the RV-8 without far too many follow-on implications. I've temporarily suspended my efforts to engineer a solution, and have decided to press ahead with the standard setup. The few times when I would have liked having a parking brake don't seem to justify the effort right now.
Fuel pump clamped in place.
Using a coat hanger wire to figure out the fuel line bends.
Bending of the first fuel line (from the filter to the pump) is underway.
