Today I finished fabricating the three angle pieces that will mount the strobe power pack to the left side of the fuselage in its new location. I clamped and drilled them to the longerons just behind the aft baggage compartment on the left side. Next, I'll prime/paint them and mount the platenuts. Since both the ELT and the strobe pack will now be on the left side of the fuselage, I'll have to run the "noisy" strobe power wires over to the right side to keep them away from the lower-power and antenna leads that generally run up the left side.
