Buck's RV-8
Date: 6-28-2008
Number of Hours: 5.50
Brief Description: Landing gear
Today was another nice milestone in the construction of N18XL -- I began mounting the landing gear legs.
First, I drilled the second inboard wear plate (the one I couldn't drill last night), and this time I used the proper tool. Here's a big tip -- when you're drilling 4130 steel, do NOT compromise with either the drill motor or the drill bit. A 7/16" Cobalt bit costs about $8.00, and it's worth every penny. I also upgraded to a 1/2" Bosch heavy-duty electric drill. The combination of slow speed, high torque, and a sharp, new bit made all the difference. The steel wear plate was downright EASY to drill. Steel chips flew everywhere.
Next, I leveled the fuselage, mounted the gear legs, and attached each of them temporarily with a single 7/16" bolt. I then began aligning the legs by clamping a pair of 6' steel angles to the outboard flat surface of the bottom of the gear legs. I leveled them and dropped plumb bobs from each end, and dropped two more from the forward and aft ends of the fuselage centerline. I played with the measurements for a couple of hours in an effort to get everything perfectly aligned, but I realized that mounting the gear while the fuselage is on the rotisserie is not ideal. There's a slight amount of slack and wobble that I can't eliminate. I began building a custom sawhorse to go underneath the forward fuselage. It's made from the remnants of my tail jig. (Remember those?)
The right tool for the job!
The fuselage has grown gear legs!
My method of aligning the gear.
