I spent a little time trying to figure out how I might be able to mount the Matco MC-5 brake master cylinders to the pedal assembly. The cylinders are much wider than the stock ones, and they hit the pedal weldments. More research is needed.
There are several clearance issues with these larger master brake cylinders.
