Buck's RV-8
Date: 7-11-2007
Number of Hours: 3.50
Brief Description: Right side console
In order to finalize the exact location, size, and shape of the side console, I had to attach the instrument panel. I cut and filed the F-803CPP attachment flange as specified in the plans, then clecoed the flange to the panel assembly. Next, I drilled and clecoed the small flange segments at the lower corners to the fuselage skins, which established the tilt of the panel.
With the instrument panel in place, I finalized the dimensions of the side console by carefully trimming, filing, and sanding it. As I mentioned in a previous entry, I didn't like how the console extended aft beyond the F-804N channel cap by about 1 inch, so I cut the aft end of the console off and fabricated a new aft end-piece for it. Now it sits flush with the aft edge of the channel cap. I think it looks a lot better -- not to mention the fact that now I'll be able to utilize the space aft of the console for a map case.
Just for grins, I held the WD-814 rollover bar in place on the fuselage longerons to check its fit. It looks like it'll have to be spread by about 1/4".
The side console, trimmed to be flush with the aft side of the channel cap.
I built a new, removable piece for the aft end of the console.
A view of the underside of the console, just for reference.
