Riveted the attach angles to the flap switch console and the top of the throttle quadrant.
Fabricated the sloped attach angle for the stock right-side console and drilled/clecoed it to the fuselage skin . I'll use this as the basis for an attach point for my custom side console.
Fitted, drilled and clecoed the right-side vertical channel cap (F-804).
Since it's almost time to install a bunch of stuff back in the tailcone, I measured the floor of the fuselage near the baggage area in preparation for cutting temporary oak floorboards. I also procured a wooden pallet that might work as the base of a temporary fuselage stand.
Attach-angles riveted to flap switch console and the top of the throttle quadrant.
