Fitted and drilled the forward baggage floor to the support structure.
Fitted and adjusted the F-871PP forward baggage side panel. (The three already-installed platenuts in the front side of the the gear tower seem very, very tight. Even with Boelube and quite a bit of torque, the #8 screws do not want to go in past the halfway point. I'll have to investigate this further. Perhaps I'll need to run a tap through them.)
Countersunk the appropriate holes in the F-870C angle and installed the platenuts.
Dimpled and primed the right edge of the F-870PP floor, where the angle will attach.
Touched up the primer on parts of the aft cabin side covers where they were filed and sanded last week.
Drilling the four holes that attach the baggage floorboard to the side panel.
Two of the four platenuts installed on the F-870C attach angle.
