Brief Description: Cockpit side console; axle-nut wrench tool
I finally received some more aluminum angle today, so I completed the last mounting angle for the cockpit side console. I also finished priming all the components and riveted the six platenuts to the attach-angles.
I also took some time to build Van's cool little axle-nut wrench. It went together in about five minutes, not including polishing it. It should come in handy someday.
(Entry continued on next page.)
The final stiffener, ready to be drilled to the side console.
Platenuts riveted to some of the attach-angles.
This is Van's $8 you-build-it axle-nut wrench. It's just as high-quality as their airplane kits.
