Nearly completed assembly of fuselage rotisserie stand. Had to file the holes on the aluminum firewall angles slightly oblong, and also the center hole through the front mount arm, in order for the bolts to fit.
All that remains is to lift the fuselage up, swing the front stand upright, level the back end, clamp and drill rear attach fitting, insert rear bolt, then drill various rotation-lock holes in the front mounting arm. I also need to buy an eye pin as specified in the instructions.
Jeff Bordelon fuselage stand -- a nicely-engineered product.
Awaiting three friends to help me lift and mount the fueslage.
