Buck's RV-8
Date: 6-5-2010
Number of Hours: 8.10
Brief Description: Elevator bellcrank access hatch
I guess this hatch should technically should be called an ELT/Strobe/Autopilot Servo/Elevator Bellcrank access hatch, because it will allow some visual access to all of those items. Today, I finished the project. I completed the shaping and filing of the cutout, cut all the hinges, stiffener angles and spacer pieces to size, and cut the door down to its finished size. Next, I taped all the components firmly in position and inserted the hinge pins while I back-drilled the hinges. I bent the forward edge of the hatch slightly to get it it seat flush with the baggage floor. Then everything got sanded, cleaned, prepped, primed, dimpled, and riveted. Finally, I bent the hinge pins into the necessary shapes and drilled the "keeper" holes for them in the wall below them.
This project was a nice one to get me going on the project again. I think it will be a very useful modification. Thanks to the guy on VAF from whom I stole the idea! ;-)
Hatch, assembled. It's held in place with two removable hinge pins.
The lower end of the pins go into the two small keepr holes in the baggage wall.
View showing the construction of the hatch and the shape of the pins.
