Removed skin. Moved coax cable to give more slack on top end (for future antenna puck removal.) Re-clamped coax and re-clecoed skin. Riveted skin to skeleton. Left 8-10 open holes near leading edge and around antenna puck. Drilled out and replaced two rivets along the way. The rivets in the VS skin are easier to buck than the ones in the HS were.
