Finished planning, and acquired parts for, mounting VOR/ILS antenna. Bought parts (Adel clamps, bolts, nuts, washers, nutplates) from Poplar Grove Airmotive. Drilled skin to skeleton. Filed ends of ribs to match skin edge. Removed and deburred skin. Sanded edges of skin. Deburred skeleton. Fabricated two new doubler plates for VOR/ILS antenna, since assembly is now further forward than before, and therefore must be narrower. Clamped both plates to top rib and drilled nutplate holes. Used swivel deburring tool again to enlarge coax cable hole in top rib.
