Aligned, drilled and clecoed front spar on ribs. Aligned front rib, bent its rear flange, then drilled and clecoed rib to front spar. Sanded, polished, cleaned and primed front spar and front rib.
Front spar clecoed to ribs.
Drilling front spar to ribs. A 12" drill bit is a necessity here.
