Today I spent a lot of time getting my shop equipment in order, organizing the various parts I've already made, and generally getting my head back into the construction process.
I picked a nice easy project today: Drilling and cleacoing in place the Effectus Aerial Products' tail light attachment ring to the bottom of the rudder fairing. I drilled the center hole for the wires to pass through, then opened it up so that four offset bullet connectors can pass through. This will allow for easy removal and replacement of the LED unit if it ever needs to be changed out.
The ring will be riveted in place with blind rivets once the the airplane is in final assembly.
