Buck's RV-8
Date:  8-19-2008
Number of Hours:  1.50
Brief Description:  Wiring bushings and routing planning
Yesterday, I took a dozen or so pictures of the inside of the fuselage, and today, I mounted the 8.5" x 11" photos on a foam core board. I began drawing some of the various wires and key components that will live under the floor, planning where the wires will go based on their function and how "noisy" or "noise-sensitive" they are.
I also drilled another four or five holes, and installed snap bushings in several bulkheads.
I'll use this photo board to plan the route of each wire. (Crazy, ain't I?)
This grommeted hole will be used for the smoke oil line and perhaps a couple of wires.
