Buck's RV-8
Date:  1-8-2008
Number of Hours:  5.50
Brief Description:  Front seat; annunciator panel
Lots of great progress on my new annunciator panel design. I cut and drilled a piece of 0.063" aluminum as a prototype mounting plate for the LED light assemblies, including holes at the corners for the #6 screws that will attach it to the instrument panel. If this layout scheme turns out to be an aesthetic success, I'll cut the final version with a CNC mill so all the holes are perfectly in line.
I also created the printed legends that will fit inside the light assemblies. I used Avery Clear labels, printed in Bold 10pt "Franklin Gothic Demi" font. (I originally tried "Arial Narrow," which fits and looks nicer, but the weight of the characters was a bit weak, which made the labels a bit harder to read.)
I also researched ways to dim the entire annunciator panel using a potentiometer on the ground side of the lights. I'll test this method sometime soon.
Finally, I spent a couple of hours installing the various platenuts that will attach the front seat to the floorboard and the aircraft structure.
The prototype annunciator panel, laid out on 0.063
The prototype annunciator panel, laid out on 0.063" sheet.
A home-made annunciator legend, made with a clear Avery ink-jet labels inside the light cover.
Front seat support ribs, primed and mostly riveted together.
