Buck's RV-8
Date:  12-23-2014
Number of Hours:  0.30
Brief Description:  Dynon compass D3 service update
A few years ago, Dynon announced a modification that needs to be done to the D-10A's compass. Today I accomplished the mod. It's pretty simple and straightforward.
The procedure has you take off the cover the compass module, locate D3, a tiny surface-mounted diode, and carefully clip it off the circuit board.
This mod was needed to correct an issue with the accuracy of some of their Outside Air Temperature (OAT) probes.
A look iinside the Dynon magnetometer (compass module).
No trace of D3 left.
