Brief Description: Avionics ground bus (version 1); other wiring
Today, I finished the construction of an avionics ground bus (version 1). I soldered the ends of two 14AWG ground wires across all 25 pins on the back of the male D-sub socket, strain-relieved the wires, ran them out a grommeted hole in the case, and sheathed them in nylon wrap. The box will be mounted once the top skin is riveted in place -- some day far down the road.
I also ran a couple more wires from the aft fuselage to the panel area (DVR power, specifically), ran the smoke oil line the rest of the way through the airplane to the engine compartment, drilled a few more wiring holes through various bulkheads and the spar, and installed a few more rubber grommets.
Avionics ground bus, version 1.
Almost ready for installation. Just needs some wire sheathing.
