Buck's RV-8
Date: 9-19-2007
Number of Hours: 4.50
Brief Description: Floor stands and work floorboards
Today, I designed and built a couple of stands that will support the fuselage at floor level, which will allow me to crawl inside to do the remainder of the work in the rear fuselage.
The forward stand is nothing more than a couple of 2x4s, some 10"-long sections of 4x4s, and some 6" scraps of 2x4. The 6" scraps were screwed on to make narrow channels for the false, wooden spar to sit in.
The tail support will be a customized, 17-3/4" tall sawhorse. I'll rest the tailwheel spring tube in a padded notch in the sawhorse. (Tomorrow, I'll try to mount the tailwheel tube to the airplane.)
I also built a wooden floor for the inside of the fuselage out of 3/4" oak. I'll need to make another one for the fuselage bay aft of this one, but because I haven't been able to crawl in there and measure it, I don't know the dimensions of it yet.
After all the woodwork was done for the day, I installed the aft floorboards in the airplane. This will allow me get in and out without damaging anything.
The first of two work floorboards in the aft fuselage. The other one will be farther aft.
The forward fuselage stand is simple and sturdy. Should work just fine.
The airplane's tail will be supported by this stubby sawhorse with a notch cut in it.
