Buck's RV-8
Date: 12-30-2014
Number of Hours: 3.50
Brief Description: R flap
This was a nice, productive day. After a lot of reading and consideration, I decided to go with a modified flap rod attach point for the flaps. The stock, studded rod-end bearings simply will not work without creating another, larger problem -- namely, a tall hole in the fuselage that interferes with the flap fairing.
So I used a new straight rod-end, a pair of medium-sized 1/4" fender washers to capture the bearing, a 9/16" machined aluminum bushing from McMaster-Carr, and an AN970-4 fender washer with one side partially ground off. This setup accomplishes the same thing as the original, but moves the bearing about 1/2" further out from the flap. I think the load is reasonably distributed, and the stress points are minimized. Because I'm using an AN4 bolt as the main connector instead of the stock bearing stud, I was actually able to use a full-size AN365 nut on the inside of the flap rather than the thin-profile nut called for. Even better, I can still use the aftermarket Avery flap rod that I wanted to use.
I cut and gound down a cheap 7/16" wrench to more easily reach the nut inside the flap. This makes the job a lot easier than what I've been doing. You don't want to know.
I mounted the flap, installed and adjusted the flap rod, trimmed the flap hole to its final size and shape, and connected everythingl up. The excitement of the night came when I ran the flap up and down using the electric motor! What a great feeling to see that happen!
To celebrate, I took off the flap and trimmed the inboard top skin to its final shape, which I derived from a plastic French curve tool that I bought at Hobby Lobby. Aesthetically, it now looks "right."
The new, modified flap rod attach point, and my modified wrench.
The right flap rod hole, in its final form. Just needs to be filed and sanded a bit.
The final profile of the flap. Drawn with a French curve template.
