After several years, I waded back into where I left off on the wing forward attach angles. I began by resuming the process of filing a bit of material off the backside of the angles so they lay flat against the fusealge sides.
I also spent a bit of time re-familiarizing myself with all the components in the wing root area, and figuring out what tasks I need to complete, and what order I should do them. I'd like to finish up the wings completely in the next month or so.
Forward attach angles
Filing and polishing the back side of the angles so they lay flat on the fuselage.
