I trimmed and mounted the right flap this afternoon, which required a bit of zen to get started. Since there is no accurate drawing that shows the exact trim line that will be required, you have to make your best guess and trim off a bit at a time until the flap fits along the fuselage skin. I managed to get it pretty close -- it will still require some final trimming and sanding later.
