This evening I got the right wingtip drilled and clecoed. I had to do some additional trimming and sanding on the tip flanges and leading edge to make it fit well. It still will need quite a bit of work on the trailing edge to make it line up with the aiileron. I'll also need to tweak the fit slightly as I drill the holes up to final size.
Beginning to drill and cleco.
Here's how I used duct tape to pull up on the tip while drilling the attach holes.
