Riveted W-413-L inboard aileron hinge bracket to spar. Used rivet gun with offset head because neither squeezer nor straight head would fit alongside bracket.
Completed installation of pitot line out to the 45-degree fitting in the rib. Re-installed aileron bellcrank. Taped protective sponge rubber to pitot line and spar to prevent damage from movng bellcrank.
