Brief Description: Pitot line; remote compass; L aileron
Fabricated and installed aluminum pitot line from rib fitting to pitot mast. Test-ran Dynon remote compass wiring through conduit. Began assembling A-407-L inboard aileron bracket. (Will order #11 drill bits for drilling AN-3 bolt holes in these brackets. #12 bits are just slightly too small.)
The line can be removed through the pitot mast with a certain sequence of twisting of the pitot tube.
