Tonight I did the first wiring in the forward fuselage -- the two 10 AWG connector wires between the main bus, Schottly diode, and Essential Bus. I used a RhinoPro 3000 label maker and yellow heat-shrink labels. The connectors are PIDG ring terminals with double-wall heat-shrink. I used K-nuts on the connections.
Main Bus (left), Schottky diode (center), and E-Bus (right)
