Buck's RV-8
RV-8
VS final assembly
Dimpled skeleton. Top rib was evidently mounted at a 94-degree angle instead of 93 degrees. Rivets will be slightly off-center (toward the web of the rib). Had to grind a flat edge on the female dimple die to reach some holes.
RV-8 Home
1415
Avionics/Electrical
84
171
Design Philosophies
216
Fiberglass
656
Planning/Studying
Shop
Wing-L
Wing-R
Wings-Misc
25
78
