Buck's RV-8
Date:  9-17-2006
Number of Hours:  0.60
Brief Description:  Fuel sender fabrication and fuel tank attach bolts
Removed all four bottom wing access covers and checked torque on all fuel tank attach bolts, in accordance with Van's special notice sheet. Found at least four bolts not tightened to 20-25 in/lbs. Tightened bolts.
Tested both fuel senders with ohmmeter -- values were nearly perfect. Fabricated fuel sender float arms. Attached floats and arms to senders.
The wires were easy to bend using my new bending brake.
Completed fuel float/sender assembly.
