Buck's RV-8
Date:  3-13-2019
Number of Hours:  0.50
Brief Description:  RCP USB Port Upgrade
Getting back to work on the RV! In the last 4-5 years, USB charging has become THE mainstream way to charge devices, so I decided tro pull out the old Powerlet sockets that I'd installed, and install new USB charging ports. The first one to be replaced is the one on the right side of the rear cockpit. Today, I laid out a new attachment plate on some 0.40 aluminum sheet.
The charger I'm using in this location is made by Radiant Instruments (Belite Aircraft), and it's supposed to be tested and suitable for aircraft use, with no interference or EMI.
Laying out the charger attach plate.
