Buck's RV-8
Date:  1-28-2015
Number of Hours:  0.80
Brief Description:  Annunciator panel
I assembled all 9 lamp assemblies for the annunciator panel, using thick CA glue to secure the white LED shroud pieces inside, and thin CA glue to secure the end caps. Three of the lamps need additional components across their leads, and I tried fitting these inside the housings, but there wasn't quite enough room. Therefore, they will be soldered onto the leads externally once the glue dries.
The assembled annunciator panel lamp fixtures.
