I finished assembling the circuit box for the annunciator panel, and began modifying the lamp assemblies. The new LEDs I'll be using are much brighter that the original ones, and their flat faces distribute light more evenly across the lenses. I trimmed off the old solder lugs and drilled two new holes in each of the bases for the LED leads to stick out.
The circuit box is done!
Beginning to modify the lamp assemblies with new LEDs.
