Buck's RV-8
Date: 12-18-2014
Number of Hours: 0.70
Brief Description: L wingtip rib
Almost done with the wingtips! Tonght I riveted on the L wingtip rib, and also tested some paint that I'll use on the nav light lenses. I painted four different samples on some scraps of the Lexan material I cut the lenses from:
1. "Plastic" paint, un-scuffed surface. 2. "Plastic" paint, scuffed surface. 3. "Polycarbonate" paint, un-scuffed surface. 4. "Polycarbonate" paint, scuffed surface.
I bought both paints from a local hobby shop. I plan to subject both samples to some semi-scientific testing, subjjecting them to high speed rain, cold, heat, and abrasion. The winner will get painted on the lenses.
I also cleaned up the lenses themselves with Plexis plastic polish. They look really good now.
The third photo below show the way I painted the light cove so that there is ample surface area to bond the reflectors on. I will be removing the paint from the right wingtip in the same pattern.
L wingtip rib riveted in place.
Paint colors: Steel Gray and Silver. Not sure which one I like better.
Wingtip light reflectors will be bonded to the fiberglass, with the black showing around the edges.
