1. Cleaned up the wiring harness on the L wing rib, including re-routing everything up a few inches to keep the power wires slightly further away from the Marker Beacon antenna.
2. Improved the airframe ground for the landing light.
3. Added an Adel clamp to provide more strain relief for the ground above.
4. Installed a 4-conductor Seal-All connector to the end of the nav/strobe light cables.
5. Installed a BNC connector on the end of the Marker Beacon antenna coax.
6. Installed a mating Seal-All connector and some sheathing on the nav light itself.
4-pin Seal-All connector for the L wing nav/strobe light.
The L wing nav/strobe light, with connectors attached. The housing will be attached later.
