Several miscellaneous little jobs today: - Safetied remaining attach bolt on autopilot pitch servo. - Began wiring to rear cockpit map light. Drilled attach hole for Adel clamp and installed grommet just aft of the rear seat throttle quadrant. Drilled hole in floor support for conduit. - Ran 1/4" nylon conduit for wire.
Aft servo attach bolt, safetied.
Nylon conduit for the rear cockpit map light wiring. The area on the left will be covered.
