Buck's RV-8
Date: 11-18-2010
Number of Hours: 2.50
Brief Description: Avionics ground bus (version 2)
In the last few days, something began bothering me about Version 1 of my avionics ground bus. The 25-pin D-sub connector I'd used was the "solder cup" style, and the two 14-gauge wires I'd soldered to the back were not really mechanically secure before soldering. Mechanical security of a joint is one of the primary rules of soldering (especially for a connection that will be so critical, and subject to vibration, as this one). Honestly, it probably would have been fine, but I just can't compromise -- not with an avionics installation I will trust with my life someday.
So today I re-built the whole thing, this time using a different style of D-sub connector I got from a local electronics store. This one is a female 90-degree PC-board mount. Its long leads make it easy to curl the pins around the ground wires before soldering.
(UPDATE: Although this design might be adequate, I will be re-designing the avionics ground bus yet again. Version 3 will feature the D-sub socket soldered to a custom PC board inside the housing. The two 14 AWG ground wires will be soldered to the PC board. More in the next entry...)
Avionics ground bus (v2), before soldering. Longs pins now give mechanical security to the connection.
New avionics ground bus (v.2), installed. Ground lead goes to to the main firewall ground.
