Today I cleaned up the wiring under the vertical stabilizer where the VOR antenna wire and the tail camera wire make their way from the VS down into the fuselage. This area has a lot of sharp edges and twists & turns, so I had to use thick-wall plastic tubing to protect the wires in several places.
I also spent a bit of time figuring out exactly where I'll be locating some of the electrical "black boxes," namely the Safety Trim box, the lighting controller, and the EFIS backup battery. More to come.
These two wires are zip-tied to an adhesive mount on the top of the horizontal stab spar.
