Buck's RV-8
Date:  6-14-2010
Number of Hours:  1.50
Brief Description:  Main switch panel improvement
Today I began installing platenuts along the inboard lower edge of the main switch panel. This will allow me better maintenance access to the switches later if I ever need it, as well as making wiring the panel a lot easier. The left side plate of the panel will now be removable, so instead of having the remove the entire panel to change a switch or re-wire something, I'll just remove 8 screws and be able to do it.
