Brief Description: Duct install, Oil hose attach, Cables ran
Finished the install of the Radiator duct. Had to drill different hole to get the clamps to properly attach to the engine mount. Then had to open up the holes we did use. The ducting does not fit perfectly for sure.
The oil hose from the bottom of the engine to the oil tank was mounted and wired. The hose is too long so we are going to cut about 4-5" off of it so it fits without being sloppy and having a big bulge in the hose.
Drilled the holes for the Throttle cables and the Choke cables in the firewall. Started to run the cables. Going to watch the videos Rans says we should watch on www.rotax-owner.com/ tonight.
