Brief Description: Spinner assembly and Cowling fitting
Finally back to work after a Month of vacation!
We started the spinner assembly and continued the fitting of the cowling.
We cut out the Spinner as per the Book but then did not like the clearances for the blades and ensured they would not be conflicting with the blades or the hub.
We got the cowling to where we can call it close enough to finished to continue on with putting on the 1/4 turn receptacles. Then after they are all installed and the cowling put back on. We can inspect and do a final fitting if needed.
