Inserted instrument panel between Top Boot Cowl skin and Instrument Panel Frame. Did not need to trim it.
Drilled all holes out in Boot Cowl to #30.
Trimmed bottom skin to the centerline of tubes.
Riveted Firewall Support Angles to Firewall but not the ones to the tabs.
Took the entire Boot Cowl off and Deburred all holes. We did not rivet Boot Cowl side Skins to Bottom. Did not rivet stiffeners to the dskins either. Did not apply High temp silicone to firewall. We need to do this at the fianl assembly.
06A-01, Items 3.
Cleoco'd Instrument Panel to Instrument Panel Frame Transfer Drilled Panel Holes to #11.
