Bob's Web Site
Date: 2-24-2015
Number of Hours: 7.00
Manual Reference: Text05C-01
Brief Description: Wing Rib Assembly
Finished Rivetting Clips to Ribs #2,3,5,6,7,8,9 & 10 for Right Wing. Loosen Drag Braces and Cleco'd Ribs #2,3,4,5,6,7,9 & 10 to Spars. Riveted clips to Tip Bow spar and then rivetted rib to Spar.
Started the Fuel Cap assembly. Drilled holes for fuel sight gauge in fuel tank. Located and drilled hole for the fuel cap assembly. Cleaned out the left fuel tank with vacuum. Located and drilled hole for Fuel cap assembly in top of fuel tank.
Located and oriented Upper Root Skin. Cleo'd in place.
Closest wing is the left and Right in background
Left wing
Beginning of Fuel Cap assembly
