Adding oil to the engine. This procedure is much more complicated than I thought it would be.
We watched a video on how to properly add the oil and start the engine for the first time. We could not get theBig Red X over the Oil PSI to go away. We discovered we had to go into the EMS page> Sensor Mapping> Pin 6 and change to the Honeywel oil pressure. So we did that and still the Red X would not go away. Started checking the wiring and finally found out the red wire in the connector to the Oil Pump which sends out Oil PSI was cut and not making a good connection. This was in the condition we received it. Oh well, another day with virtually little getting done, just trouble shooting.
