Modified on Boot Cowl Strip to 30". Positioned inside Firewall Support Angles tabs. Transferred drilled to #30 and cleco'd
Inserted cowl strips on both sides of Firewall, inside of remaining tabs of Support angles. Transfer drilled to #30 and cleco'd.
Suppose to trim the lower ends of the strips but did not until we do our final assembly probably.
-Called Mark Pringle and discussed the estimate we received from him and Alina on the Dynon Skyview. He will correct some of the estimate and then we said we want to order it now.
